Issue with Sort 1D Array.vim and VI Refnum
Hello all,
I am having an issue using the Sort 1D Array.vim which allows you to pass in a custom "less-than" function to sort things.
In my case particularly, I am sorting DAQmx physical channels by order of PXI#, Slot#, and then ai#.
I have coded the less-than function this way:
When I attempt to connect this to "Sort 1D Array.vim", I get this:
I seemingly have done this correctly, however, it doesn't work...
I would greatly appreciate some help.
Message 1 of 9
(3,628 Views)
If you look at the shipping example (lesson 2a), the connector pane is actually different for the VI refnum scenario. Maybe change to that and see what happens....
Message 2 of 9
(3,617 Views)
I switched the tunnel pattern to match that example but I still get broken wires when attempting to wire it into Sort 1D Array.vim...
Message 3 of 9
(3,611 Views)
It would help if you could attach the VI.
Message 4 of 9
(3,609 Views)
Attached is the "less-than" VI for DAQmx physical channels.
I also attach a vi demonstrating the various ways i've attempted to connect this to 1D sort.
(I'm using LV2021)
Message 5 of 9
(3,603 Views)
Sorry, I only have LabVIEW 2020 here...
Message 6 of 9
(3,583 Views)
Attached LV2020 version
Thanks for trying to help!
Message 7 of 9
(3,579 Views)
Accepted by topic author Gryffin
removing the two extra terminals again, it is unbroken here using the strictly typed static reference.
Message 8 of 9
(3,549 Views)
altenbach,
Thanks for your help. I made a stupid mistake and didn't wire up the array of DAQmx physical channels to the array input before connecting the VI ref. Works fine now.
Message 9 of 9
(3,532 Views)
