Issue with XNET Database file(DBC or LDF)
I have one project which use XNET control module.
RD give us a dbc and ldf file (as attachment) which generated by vector canoe
now it is issue that NI-XNET Database editor cannot open the file. so i cannot use the file in labview.
what wrong with the file ? what can i do for it ?
(4,703 Views)
Hi agilentvee,
which errors do you get?
(Mind to share information about which vehicle type(s) those files are made for?)
(4,696 Views)
I cannot open the file by XNET Database editor.and the file can be opened by vector
(4,666 Views)
Hi agilentvee,
I'm using mostly NI-CAN in my projects.
Using CANGetNames from this driver determines 201 messages in the DBC file, the same number is reported by CANdb++ from Vector…
Update:
I can load your DBC file using the XNet Database Editor (LV2017SP1, 32bit, English)!
(4,648 Views)
yes, i use other xnet to open the dbc file (labview 2018)
but i use version:2020 labview.
now i transform the dbc to xml. it can be opened in 2020
(4,631 Views)
