08-28-2025 01:49 AM
Hi, I have an issue when build DaQ Assistant, it freezes the program. I use LabView2016x64 and use NI USB-6009 simulated. I appreciate all your comments. issue3.png
08-28-2025 02:02 AM - edited 08-28-2025 02:03 AM
Hi binh,
It seems you use an unsupported LabVIEW version on your recent WindowsOS…
That being said:
08-29-2025 06:16 AM
Sorry for my late response. Thanks for your comment. This is my installed location: C:\Program Files\National Instruments\LabVIEW 2016. And I have installed DAQmx 2016 correctly. I don't know how to fix this "Failed to create directory…" message . I found AF_NiAssistant file in 32 bit but my operating system in 64 bit, is this the reason ?error 2.png
08-30-2025 09:41 AM
I don't think (but I could be wrong!) that you can build a LabVIEW program that utilizes a Simulated Device provided by MAX.
There is no problem running 32-bit LabVIEW on a 64-bit Windows system. You'd be hard-pressed to find (anymore) a 32-bit Windows system ...
I suspect this Version of LabVIEW will not make the transition to Windows 11 intact.
Bob Schor
