Showing results forΒ
Search instead forΒ
Did you mean:Β
Issues installing LabVIEW
Hello all,
I'm having trouble installing LabVIEW community edition -- when I download it from the NI website, I get a .iso file. Is there a separate .exe installer I'm supposed to download? Where do I find that?
I've never had this much trouble installing software and was wondering if anyone had a solution/experienced a similar issue. Thanks in advance.
(785 Views)
An ISO file is a disk image file. In Windows and most modern OSes you can simply right click on the file and select Mount Image (or something similar). This will mount the image as a virtual disk volume and then you can access it the same as you would if it was a USB Flash drive (or for old-timers a DVD/CD disk).
But I remember an almost identical message a week or so ago from another new member!
Rolf Kalbermatter  My Blog
(769 Views)
This is a word for word copy of a recent post (last week) also from a new member, I suspect a spambot and reporting to a moderator.
-AK2DM
(740 Views)
