Issues running our app on Big Sur 11.5
We have an app that is built entirely upon LabVIEW and on macOS Big Sur 11.5 we can no longer run it.  The following error is issued by macOS:
"Insufficient permissions for action: Unable to load 'com.ni.driver.NiViPciK' in unprivileged request."
In prior versions of Big Sur we could get our app running by issuing the following commands in a Terminal:
defaults write com.company.MyApplication NSGraphicsContextAllowOverRestore -bool YES
defaults write com.company.MyApplication NSViewAllowsRootLayerBacking -bool NO
Has anyone else run into this?
-- Rick
(1,563 Views)
Did you try it using LabVIEW 2021 yet?
Big Sur support is supposed to be a new feature it had:
https://forums.ni.com/t5/LabVIEW-2021-Public-Beta/New-Feature-macOS-Big-Sur-Support/m-p/4144162
I don't use a LabVIEW for mac so beyond remembering seeing that announcement I know nothing helpful.
(1,527 Views)
Yes, we've tried with the LabVIEW. 2021 beta and it works fine.  The issue at hand is we had a solution that worked, but no longer does in 11.5
(1,506 Views)
I guess it's not compatible:
https://www.ni.com/en-us/support/documentation/compatibility/18/labview-and-macos-compatibility.html
Bill
CLD
(Mid-Level minion.)
(1,496 Views)
