Issues with communicating with two channels of a Keithley 2220-30-1 Dual Channel Power Supply
We use a VI program to communicate with a Keithley 2220-30-1 Dual Channel DC Power Supply. When we try to communicate with both channels simultaniously, an error message randomly appears:
Error -1073807360 occured at an unidentified location
Possible reason(s)
VISA: (HEX 0xBFFF0000) Unknown system error (miscellaneous error)
This originates from the Keithley VISA driver. When I use another VI program to communicate with only 1 channel on the power supply, the program runs perfectly, using the exact same VISA drivers in the block diagram. I have tried many things to solve this issue, with no success. I have attached the VI code on this post to give clarification to my problem. Where would be the best place to start to fix this?
Thanks, dglock18
(3,797 Views)
change the VISA reads and writes to "Synchronous"  Right-Click>>Synchronous I/O Mode>> Synchronous.  the watchband glyphs are a dead givaway that "Asynchronous" is selected.
Keithley may eventually learn to properly buffer commands.
(3,791 Views)
Niether the instrument or the GPIB standard supports simultaneous communication. GPIB is and will always be a sequential communication bus. Jeff''s recomendation forces that on your program but it should be rewritten to reflect reality.
(3,788 Views)
Keithley's are notorious for having commands with different priorities.   Getting two nearly simultaneous "Immediate" commands is something their FW designers could have handled "more elegantly."
(3,780 Views)
@Dennis_Knutson - I understand, and thank you. I figured that was the case, but are you saying I should rethink my logic entirely for communicating with the Keithley? How would I be able to communicate with different two channels another way? I am fairly new to the Labview community... I'm sure this is a relatively easy fix
(3,772 Views)
Thanks Jeff! I'll try it and report back to see if that resolves the issue entirely.
(3,771 Views)
You could use the error in/error out wires to enforce dataflow. Don't have communication structures that execute in parallel. Use a single Action Engine for all communication. Use VISA Locks. All different possibilities.
(3,764 Views)
