Issues with continuous acquisition and logging - Logging is not working correctly
I have a pretty complex Queued message handler VI. I press a 'Relay Power' button which triggers the following:
Relay turns on for a set time (duration), goes off for a certain time (Delay) and repeats.
Every time this happens, I log data to a text file during the 'delay' interval.
For example, lets say I want to create 2 log files.
Duration: 1000ms
Delay: 1000ms
Files saved: File1, File2
File1 appears to be correct, ~1000 sample points (1 every ms)
File2 is ~2000 sample points, it logs what is acquired in the second 'duration' period.
I am not sure what I am doing wrong. The continuous acquisition examples in labview have a start/stop, where both acquisition and logging starts and stop at the same time. I don't think I want to do that?
(2,411 Views)
We can't be sure what you are doing wrong either.  It is kind of hard to help someone debug when we can't see their code.
(2,407 Views)
