Issues with subtracting Images
Here is a snippet that demonstrates the kind of code that would give you the column headings you want;
Hope that helps!
John B.
Embedded Networks R&D
Certified LabVIEW Developer
Message 11 of 13
(588 Views)
Sorry for the delayed response I have been hard at work with everything prior top this excel spreasdsheet. I did get to tery it and the first portion works for me, but where the test data is supposed to go the data is not coming out on the spreadsheet. it is a string that contains test data and timedata all concactnated together and sent out of the while loop.
Message 12 of 13
(563 Views)
Thank you for the previous post. I have used a slight manipulation of what you did and I have made some modifications everywhere else. If anyone has any suggestions on how to improve it let me know.
Message 13 of 13
(548 Views)
