It is possible to insert a while loop inside a for loop?
This is very dangerous code, because there is a finite possibility that the inner while loop will never stop, locking up the program forever.
It also seems overly complicated.
Message 11 of 18
(2,118 Views)
Are you right. This is ture, sometimes, when the signal is quite complex, the code does not stop. Please, do you have any suggestions? In wich way I could improve this cose? Many thanks, binfi
Message 12 of 18
(2,111 Views)
I think all you need is a single FOR loo. Here's what I would do. (Of course you need to decide what to return if the condition is never met, for example, so modify as needed).
(Left to right: reshape array, FOR loop, multiply, array subset, greater, search array, index array)
Message 13 of 18
(2,106 Views)
@altenbach thx for mentioning it, if for any subarray the i and (i+1) differs less than 10*i, the while will not exit
or did you mean something else?
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 14 of 18
(2,080 Views)
Yes, just run your code a couple of times. on occasion it will continue forever!
(Yes, if the condition is never met and we run out of elements while processing a row, index array will return two zeroes forever, never meeting the > condition. If you would change the condition to "greater or equal" it will return zero like my code when it runs out of elements and no match has been found because we get a 0=0-->TRUE.)
Still, my code is probably simpler. 😄
Message 15 of 18
(2,067 Views)
thats what i get, for acting without thinking, and posting pictures 😉
thx for the new icons i have never used. all in all i got some more knowledge out of it
:cheers:
Message 16 of 18
(2,057 Views)
It might be cheapest (especially with huge arrays) to avoid "reshape" and "array subset" and just operate on the unmodified array. For the inner loop, use a conditional FOR loop.
This code gives about the same result and does all operations on scalars, limiting memory use.
Message 17 of 18
(2,044 Views)
Many thanks to both!! now it is working in perfect way!! you are genius...it was a pleasure for me having your suggestions!! Thanks
Message 18 of 18
(1,997 Views)
