It is probably obvious but I can't find this VI (get all references)...
Where is this VI (LV2009 and 2013)?
(3,164 Views)
C:\Program Files (x86)\National Instruments\LabVIEW 2014\vi.lib\Utility\traverseref.llb and it is Trev Get All FP References.vi
(3,158 Views)
To locate a vi on 'my' drive I use  View-Vi Hierachy and  in the VI Hierachy window activate View-Full VI path in Label.
Greetings from Germany
Henrik
LV since v3.1
(3,145 Views)
Next time ... it should have come up with quick drop. Double click on it then save-as copy should take you to the vis default directory.
PaulG.
Retired
(3,140 Views)
quick drop should work with the help window and should show the complete path of the selected vi in the list  as an option 🙂
Henrik
LV since v3.1
(3,124 Views)
There is a quick drop which shows the file location on disk.
https://decibel.ni.com/content/docs/DOC-22461
I also wrapped this functionality into my quick drop function with the shift modifier.
https://decibel.ni.com/content/docs/DOC-31302
(3,103 Views)
In LV 2010 and later, if you enable scripting, you get a scripting subpalette under the app control palette and I think the FP traverse VI is there as well. Even if it isn't, the general traverse VI is and that has much of the same functionality.
___________________
Try to take over the world!
(3,092 Views)
