It's past time to deprecate the Sequence Structure!
I find it rather depressing how so many of the new user questions contain code that is just a big Stacked Sequence structure.
Leave the Sequence Structure there for compatibility with old (poorly written) programs, and deprecate it.
Warn users with a pop-up or the big red X like the old "Write To Spreadsheet vi" or something that this is an old outdated programming structure that should be avoided!
=== Engineer Ambiguously ===
(1,495 Views)
I mean right now it's not even on the palettes, you have to place a flat sequence structure and right-click replace with stacked sequence.
I guess you could remove that right-click option entirely but keep it as a resource so it's only accessible through scripting?
(1,457 Views)
Yes you could. And I did. 🙂
https://forums.ni.com/t5/LabVIEW-Shortcut-Menu-Plug-Ins/Remove-Replace-with-Stacked-Sequence-Menu-It...
(1,426 Views)
