It seems that NI dropped the Activex Events from the Control Panel in LabVIEW 7.0. Why???
I have Labview 6.0/6.1 Activex vi's that no longer work in LabView 7.0 There are no longer ActiveX Events vi's in the Communications->ActiveX control set. What is the deal with that??? Pretty much makes my $2400 upgrade investment worth nothing as far as I can see.
(2,562 Views)
There is an entirely new node called the EVENT node, which is a far more efficient architecture than the Activex event. I believe you will be able to do everything you want with the EVENT architecture.
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(2,562 Views)
kup,
Are you sure that your VIs no longer work? They should. The support VIs are located in "vi.lib\Platform\ax-events.llb". The functionality was not taken away, the VIs were simply removed from the function palette. Also, ActiveX Events may now also be handled using calback VIs. This is much better, IMO. Seach the examples for "ActiveX" and "callback".
-Jim
(2,562 Views)
