Iteration Issues ?
Accepted by topic author gingram536
If all you want is to keep a constantly updating from within the loops then consider something like:
This isn't going to fix your race conditions however, and a race condition is a situation where you are unsure what the data on any specific output is going to be as you travel through the program, in this case it means that at about the same time within the program you are reading and writing to the same memory space, that is part of the reason you re advised to minimise usage of local variables as they allow you to read and write information from the same place and if not properly controlled can lead to unwanted behaviour of the code.
Message 11 of 12
(890 Views)
Thats exactly what I did, a (Row Iteration*8) + (Column Iteration) to append, works like a champ, appreciate the help
as far as the race conditions, I believe I cleaned it up. not sure if there was more than 1 or 2
Message 12 of 12
(883 Views)
