Iterative solution to nonlinear equation?
Hi all,
I"m trying to put together a VI that will solve an equation of the form:
A = B*x^b+C*x^c
for the variable x (all others are numbers).  Does Labview have a block that will do the iterative solution or do I need to make my own.  I'm using Labview 8.6 Pro.
CLAD
(3,825 Views)
This is a polynomial, so you could use the "Polynomial Roots.vi".
-Jim
(3,822 Views)
Well, a polynomial if b and c are integers.  If b and/or c are real numbers then you will need a zero finder.  There are two available, named "Newton Raphson Zero Finder.vi" and "Ridders Zero Finder.vi".
-Jim
(3,820 Views)
Thanks Jim!
I'm trying to get the Newton Raphson solver going right now, but it keeps giving me a syntax error.  I'm feeding it a string that looks like:
50.00=0.019231*(2*a)^0.15+675*(2*a)^0.5
I've built this string programatically.  Is there something I'm missing here?
CLAD
(3,800 Views)
Newton Raphson is expecting something like "expression=0", but the =0 is implied.  Try this.
0.019231*(2*a)^0.15+675*(2*a)^0.5-50
-Jim
(3,789 Views)
Ah.  Now it's working.  Thanks again!
CLAD
(3,783 Views)
