J, T, E, K type Thermocouple readings stop reading temperature
I have attached a J, T, E, and K type thermocouple to an NI cDAQ-9184. When I run my VI the readings for all thermocouples match and are correct at freezing, boiling, and room temperature. After a short period of time the readings begin to drop to about -260 C and create a sinusoidal signal. The thermocouples will read correctly again if I interact with them, AKA. apply heat. Then they will read correctly for a short period of time before decreasing into the same incorrect sinusoidal signal. I have attached pictures and my program to this post.
(1,040 Views)
(1,026 Views)
Hi GHAHWT,
The cDAQ9184 is just a chassis. Which module(s) do you use? How do you connect your thermocouples?
Do you get any errors from your DAQmx reading?
Please define "short period of time"…
Unfortunately you use the latest LabVIEW version many of us cannot open. Mind to attach a downconverted version of your VI? (File->Save for previous)
Your image is next to worthless as you attached a downscaled version of the image. It's just blurred and unreadable.
But still I can see "bad" code: DAQAssistent ExpressVI, lots of SplitSignal and unneeded indicators!
  • Replace the DAQ ExpressVI by plain DAQmx code as is shown in all those DAQmx example VIs…
  • Avoid using the DDT wires. It just hides the underlying data…
  • When you want to show numeric data next to the chart then you just need to ake the "digital display" visible. No need for additional indicators!
(1,026 Views)
Hi GHAHWT,
do you really need to read thermocouples at 1kS/s?
(And why did you need to create two threads for the same problem?)
(968 Views)
