JPEG to image without files
I have an application that has been running for some time now and a lot of acquisitions have been done with it. During one acquisition, I get roughly 1000 images that I save on disk in a JPG format. We are now moving the data storage to a centralized location in a database and I want to do the following:
1 - Insert the raw bytes of the JPG file in the DB
2 - Insert new LabVIEW images in the DB, compressed in a JPG format
3 - Load and display images saved in the JPG compressed format in the DB
Element 1 is really easy to do and I am already doing it. For elements 2 and 3 though, I can't seem to find a way to skip writing/reading to disk. I know how to use the "Write to JPG" VI for example but that slows down the process a lot because of disk access. It would be much faster if the data could be uncompressed directly to/from the memory.
Is there a way to use LabVIEW VIs to compress the image into a JPEG format and return a byte array instead of writing a JPG file on disk? Also, I would need to be able to do the opposite as well (i.e. pass an array of raw bytes representing the content of a regular JPG file and get a LabVIEW image out of it)
Thanx!
Olivier
(2,824 Views)
could you just store the new data into the DB without making it a JPG and when you want to actually pull the data out to look at it just generate the JPGs then?  that might make it faster for you.
(2,821 Views)
It is an option, but the compression factor of the JPG file format makes it a more suitable solution in the long run. The imaegs could be compressed differently since I'm saving binary data anyways but because I already have all those JPG file, I would like to stick with that.
Also, I know that the compression algorythm exist somewhere, it's just a matter of whether we can access it or not.
(2,816 Views)
LabVIEW's function that does the jpg compression also stores it to file. The
data is not accessible.
I'd try http://gnuwin32.sourceforge.net/packages/jpeg.htm or another
external jpg compression library.
Wiebe.
(2,775 Views)
