JSON string to HTML
Please Guide me to convert the table data with properties to JSON format
(1,279 Views)
Hi Mannaa,
Please explain what you really need!
Your thread title wants "JSON to HTML", your message texts needs "data table to JSON"…
Please provide examples for your input data and the expected output data!
(1,273 Views)
My requirement is I need to create a test report with JSON format. My issue was If i save the table in JSON format it only save the data. I need to save the table properties also in JSON format. because after saving the report in JSON format I need to read the report in HTML format also. I want table properties like below while converting JSON format.
(1,260 Views)
Hi Mannaa,
Where do these tables/table properties come from?
How do you convert "table to JSON" right now?
Why can't you read the table properties and add them to your JSON formatted text?
(1,245 Views)
