Jetson nano mate cluster
I have a jetson nano mate and four, 2G jetson nano with 32 scan disc in each one.
https://github.com/garyexplains/examples/blob/master/how_to_build_nvidia_jetson_gpu_cluster.md
Here are the steps to set up the cluster I will be doing it this weekend. Any recommendations or ideas on what I can do with it on LabVIEW
(1,391 Views)
Very little if you just expect to install some ready made library and play with it. Maybe the Haibal library will be interesting for you once it is released. It is supposed to work with CUDA if you have NVidia GPU hardware in your computer.
Rolf Kalbermatter  My Blog
(1,354 Views)
Thanks for the reply and I will check it out.
(1,350 Views)
