Job qualification
what is the qualification to get LabView job? Do I need to get a certificate, a degree?
(1,614 Views)
First of all, you should learn to properly spell LabVIEW (notice the capitalizations).  Otherwise, it depends on the actual job.  Many require some type of engineering degree (I mostly see Electrical Engineering, Mechanical Engineering also common, sometimes I see a Computer Science).
(1,585 Views)
