Json to Cluster and Cluster to Json
hello,
please I have a little problem in the conversion of (json to cluster and cluster to json) I want to convert <Json string> to cluster, to write information in it and I used the following program, then I convert this cluster again in json, but I'm not getting the ordered result like before.
Do you have any suggestions ?
O.
(1,251 Views)
The ordering of the cluster is used.
You can change it, by right clicking the cluster and choosing "Reorder Controls In Cluster".
You should also look into type definitions.
Yes, post the code not images.
If you post images, embed them in the text (saves us a download, open and delete).
(1,238 Views)
