Jump in Sequence
Hello everybody,
is there an option to jump to the last frame of a sequence with a button, or just finish the sequence earlier than being through all the cases?
Thx for any help
Michael
Message 1 of 8
(5,727 Views)
No, that is why the sequence structure should be avoided. Use a proper state machine.
Message 2 of 8
(5,718 Views)
Michael,
do not use the sequence structure. You cannot "jump" between frames, they are strictly sequential (hence the name!).
What you can/should do is to replace the sequence structure with a state machine. With that architecture, you can implement any "jump".
Norbert
Norbert
Expert: Geometry
Message 3 of 8
(5,716 Views)
No there isn't -- which is why you should NEVER use sequences in deliverable code. As a starting place, check out the state machine design pattern.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 4 of 8
(5,715 Views)
@Dennis_Knutson wrote:
No, that is ONE ISSUE why the sequence structure should be avoided. Use a proper state machine.
Added one important note above. The sequence structure has several issues. There are only spare use cases where it is suitable, in most of these, the structure will only have a single frame!
Norbert
@Dennis: Wanted only to strongly endorse your statement 😉
Norbert
Expert: Geometry
Message 5 of 8
(5,711 Views)
Holy cow! It's 3AM, isn't anybody asleep?!?
Mike...
LabVIEW Champion
Message 6 of 8
(5,707 Views)
@mikeporter wrote:
Holy cow! It's 3AM, [...]
Mike...
Not everywhere on this planet 😄
Norbert
Expert: Geometry
Message 7 of 8
(5,704 Views)
Mike...
My cat started to wake me up when you made this post.  So, your answer is technically "Yes".
Message 8 of 8
(5,666 Views)
