Jump out of a sequence?
I have an application in that I want a sequence to stop and jump out of
it after certain criteria is met. I don't know whether we have some way
to do it in LabVIEW 6i. Any one has a solution for this?
Thank in advance,
Guangde Wang
(3,771 Views)
> Thank in advance,
> Guangde Wang
You should not use sequence for it.
If you for some strange reason want to use sequence for this purpose
anyway, put contents of each next frame into case structure and wire
boolean local variable to that cases to trash the rest of frames. It's
not LabVIEW-like programming.
You can read in zone.ni.com for the subject "rules to wire" part2 and
read LabVIEW FAQ about stopping for loops. Issues are the similar.
http://labview.pica.army.mil/resources.html#FAQ
Sergey Krasnishov
____________
________________________
Automated Control Systems
National Instruments Alliance Member
Moscow, Russia
sergey_acs@levsha.ru
http://acs.levsha.ru
(3,771 Views)
Sergey:
Thank you for responding to my message.
What I need to do is to open a series of gas tanks. Flowmeter will check the
flow rate, if the flowrate is low enough then turn on the next tank and keep
the current one open. So the sequence will find the first closed tank and
open it. I don't want to open the tanks down the sequence, that's why I want
it jump out of the sequence.
Thank you for letting me know that we can not do it this way in LabVIEW, I'll
have to figure out some other way to do it.
Guangde
> > Thank in advance,
> > Guangde Wang
> Sergey Krasnishov
> ____________________________________
> Moscow, Russia
(3,771 Views)
What you want to do is create a state machine. You should be able to find
an example at the NI Developer Zone.
Guangde Wang wrote:
>Sergey:>>Thank you for responding to my message.>>What I need to do is to
open a series of gas tanks. Flowmeter will check the>flow rate, if the flowrate
is low enough then turn on the next tank and keep>the current one open. So
the sequence will find the first closed tank and>open it. I don't want to
open the tanks down the sequence, that's why I want>it jump out of the sequence.>>Thank
you for letting me know that we can not do it this way in LabVIEW, I'll>have
to figure out some other way to do it.>>Best regards,>>Guangde>>>Sergey Krasnishov
wrote:>>> Guangde Wang wrote:>>>> > I have an appli
a sequence to stop and jump out of>> > it after certain criteria is met.
I don't know whether we have some way>> > to do it in LabVIEW 6i. Any one
has a solution for this?>> >>> > Thank in advance,>> >>> > Guangde Wang>>>>
You should not use sequence for it.>> If you for some strange reason want
to use sequence for this purpose>> anyway, put contents of each next frame
into case structure and wire>> boolean local variable to that cases to trash
the rest of frames. It's>> not LabVIEW-like programming.>>>> You can read
in zone.ni.com for the subject "rules to wire" part2 and>> read LabVIEW FAQ
about stopping for loops. Issues are the similar.>> http://labview.pica.army.mil/resources.html#FAQ>>>>
-->> Sergey Krasnishov>> ____________________________________>> Automated
Control Systems>> National Instruments Alliance Member>> Moscow, Russia>>
sergey_acs@levsha.ru>> http://acs.levsha.ru>
(3,770 Views)
Hi Guangde,
How many tanks do you have?
Is the number of tanks is various?
Mike Manzheley
Guangde Wang wrote:
> Sergey:
> Best regards,
> Guangde
> > > Thank in advance,
> > > Guangde Wang
> > Sergey Krasnishov
> > Moscow, Russia
(3,770 Views)
Hi Mike,
Thank you for your interest. I have five tanks to rotate to make sure that there
will be enough gas supply overnight. The five tanks will rotate from first one to
the fifth one and rotate back to the first one. By detecting the first closed tank
and opening it, we do need the sequence to stop after it detectes the first closed
one and turns it open. Other wise, it will turn all the tanks open.
I think I solved the problem by detecting the first opened tank in which the gas is
running low, we'll close it and open the next tank. I have to open the next one
after the sequence, other wise when the sequence goes to the next page, it will
detect another opened tank and opens it. My program is running ok now.
There should be some other ways to reach the same goal. I do think it will be a
good feature if LabVIEW can stop a sequence when it's desired.
Guangde
Mike Manzheliy wrote:
> Hi Guangde,
> Mike Manzheley
> Guangde Wang wrote:
> > Sergey:
> > Best regards,
> > Guangde
> > > > Thank in advance,
> > > > Guangde Wang
> > > Sergey Krasnishov
> > > Moscow, Russia
(3,770 Views)
Hi Guangde,
I think, the best way is using semaphore.
Look at the LabVIEW examples/general/synchexm.llb/ Semaphore with SubVIs.vi
Mike
Guangde Wang wrote:
> Hi Mike,
> Best regards,
> Guangde
> > Hi Guangde,
> > Mike Manzheley
> > Guangde Wang wrote:
> > > Sergey:
> > > Best regards,
> > > Guangde
> > > > > Thank in advance,
> > > > > Guangde Wang
> > > > Sergey Krasnishov
> > > > Moscow, Russia
(3,770 Views)
