Jumping out of case structures other than by STOP
You need to right click and add a case. You need to name this case default.
Then you need to make this case case 0. To do this you will have to right click on the top of the case structure where the words or numbers are. See the picture below.
Next you do the same thing only select the option to make this case 0. See below.
You can rearrange all of the cases to what ever you want this way.
Tim
GHSP
Message 21 of 23
(815 Views)
Hello Aeastet,
Thanks for your advice. How do you put graphics in your answers. You have obviously made a screenshot but how do you put the screenshot into the text?
Nevica
Message 22 of 23
(804 Views)
I use the print screen and pull the screen shot into a graphics program to edit it. You should be able to use MS paint. If you want to do this. Then you just click this button to add it to the discussion forum.
Tim
GHSP
Message 23 of 23
(802 Views)
