Just 'Copy-Paste' local variables
Hi
Is it possible to copy-paste a diagram area containing local variables without creating new objects on the interface ?
Gregory
(3,220 Views)
Accepted by topic author greg31
Use control-drag instead of copy and paste.
  1. Use your mouse to select the item(s) to be copied.
  2. Hold down the control (Ctrl) key and drag the item(s) to the new location.
If you also hold the Shift key down during the move - the items stay aligned.
To move the item(s) to another diagram you don't even have to hold the shift key down.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(3,211 Views)
Hi Gregory,
If you wish to copy and paste a varibale without creating a new one. click on the variable to highlight it, then press Ctrl and drag the variable. This creates a copy of that variable without creating a new object.
Ben B.
National Instruments UK & Ireland
"I've looked into the reset button, the science is impossible!"
(3,210 Views)
Thanks to you two .
My life is much sweeter now  🙂
(3,200 Views)
