Just Installed Labview, it won't recognize previously loaded DAQmx
Just Installed LabView 7.0. Previously had Evaluation version working, even using DAQmx.
Now DAQmx is not recognized by Labview 7.0 (no DAQ assistant express VI at Functions>>Input palette).
Device Driver CD won't load because it's already there... Should I punt by removing all and reload or what?
SIDE NOTE:
Also tried to register this new S/W (purchased from NI last week) but web site (ni.com/register complains that this S/N is already registered... which is not likely as I opened the package myself)
(2,675 Views)
Try running the Driver CD again to get the DAQmx support for LabVIEW 7.0. It is quite possible that when you uninstalled, eval copy, DAQmx support went away because you don't have LabVIEW anymore.
Now that you have LV 7.0, run the DAQmx installer to get the support files.
A Rafiq
(2,675 Views)
About registering your Software issue, call your ISR (1 800 433 3488). Many times even though you just opened the package, your software could be registered because your purchasing agent may have registered the product for you.
Feroz
(2,675 Views)
