K-Thermocouple, temperature range, usb 6008...
I seem to have a problem with the temperature range with my USB 6008 board. When I connect a calibrator to it (to simulate a K-thermocouple), I can only measure temperatures between 0 and 100°C. What I would need to measure are temperatures around 500°C...
Do you know how I could overcome this problem ?
I understand the USB 6008 it is not the best board for thermocouple measuring, especially with a K type one, but it is the only one I've got...
Thanks a lot !
(4,343 Views)
Which VI are you using to acquire thermocouple data?
Try using the Acq Thermocouple sample.vi available in
..\National Instruments\LabVIEW\examples\DAQmx\Analog In\Measure Temperature.llb\Acq Thermocouple Sample.vi
BR
(4,335 Views)
Hi Anu,
thank you for your quick answer. I tried the VI you told me, but the results are erratic (ie there's no logic in the values that are returned).
For my purpose, I'm using a VI I created, because I needed to take measurements at regular intervals and add a counter. In the assistant DAQ, I configured a range of 0-600 °C, but I can't measure any temperature higher than 100°C...
If you have any ideas...
Thanks a lot !
(4,319 Views)
Can you post the VI that you are using?
Are you getting the correct temperature for 0-100 deg C? What is happening if you try to measure more that 100 deg C?
How are you taking care of CJC?
BR
(4,312 Views)
What is the common mode voltage? If the thermocouple is floating you may need to ground one or both sides through a resistor to AGND.
Lynn
(4,308 Views)
The voltage is 5V, and the thermocouple is already grounded.
Enclosed is the VI I created. Now regarding the measurements, the values between 0 and 100°C are not correct, but I believe a "formula task" in the VI will take care of that. In fact, I have a range of approximately 7.5°C (ie 0°C on the calibrator give me 0°C on LabView, and 100°C on the calibrator give me 7.5°C on LabView). When I reach 100°C, the values hit a ceiling and stay constant, whatever higher temperature I set with the calibrator.
Concerning the CJC, I basically use the default value (25). I tried changing it, but the consequences were minimal.
Is there a potentiometer on the board that could change this faulty range ? I didn't dare open the box yet...
Cheers,
K
(4,289 Views)
You do realize your setting will only have a resolution of 30 deg C. At 600 deg C, the estimated voltage will be about .024 volts
(4,286 Views)
