K-Type Thermocouple
@OEM_Dev wrote:
Just to clarify -
I believe the card you are using defaults to degrees Celsius and J-type thermocouples, not that the device you have is J-type vs K-type. But using MAX to verify your wiring is a good first step regardless when things aren't quite working the way you expect
YES, YES, YES, Thank you so much! As soon as I switched from J-Type to K-Type in the Project Explorer, it worked. Thank you!
My second issue still exists though, and that is the Ethercat randomly disconnecting
Message 11 of 13
(579 Views)
Glad to hear it. I've never used the Ethercat so no suggestions from me on that. You may want to start a separate topic, or not mark this one as solved quite yet, since people may skip it if they think it's answered.
Message 12 of 13
(573 Views)
I agree with OEM_Dev, it would be best to keep one issue per topic
Message 13 of 13
(556 Views)
