KEY DOWN in event
When use KEY DOWN in event ,this event triggered for every key (keyboard) press , the question i need event triggered for just 1 key pressed ; for example press F2 the event triggered and no triggered for the other key of keyboard ; thank you
Forza Juventus
Message 1 of 13
(4,324 Views)
Hi moussa,
the event structure also gives you some "properties" of the event as time and KEY. You have to use a simple case structure to filter for the keys you're interested in...
Message 2 of 13
(4,317 Views)
Hello GerdW ; in the example ; I need the "Event Change" increment just when i push Key F2 ; Thanks
Forza Juventus
Message 3 of 13
(4,303 Views)
You can do that, as
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 4 of 13
(4,298 Views)
Hi noussa,
which example are you referring to?
As simple as this:
Message 5 of 13
(4,296 Views)
in the example ;
Forza Juventus
Message 6 of 13
(4,268 Views)
Hi moussa,
then you should increment the event counter only in the case of a "F2" event!
Message 7 of 13
(4,261 Views)
Find modified code in the attachment.
Message 8 of 13
(4,257 Views)
And, put your Stop button in the event structure.  It is set to Switch Until Released and it'll likely never be True when it's read.
Jim
Message 9 of 13
(4,256 Views)
Hello all ;
 The problem is in the example Prd Time;
I need when i push F2 → (with event KEY DOWN) the array Production increment and the array Time saved the time of this increment production ,
and when I push other key → no event (no increment production ,no saved time )
Forza Juventus
Message 10 of 13
(4,229 Views)
