KEYSİGHT 34465A Measurement Resistance and Voltage
Hİ.
I am trying to measure resistance and dc voltage.  When ı try to measure one of them ı can get true values , but  when ı try to measure both of them ı have error: (VISA Write in Agilent 3446X Series.lvlib:Configure Measurement Trigger Parameters.vi->resistance mesaurement.vi)
I could not fix this problem .  Thanks from now for helping
(2,856 Views)
You have not posted what error you are getting.
Can you post VI snippet?
Can it measure voltage and resistance simultaneously, are you working with the same channel?
To measure resistance you need to connect fixed current through resistance and measure voltage drop on the resistance. If you simultaneously measure external voltage .. if I was device, I would get confused. Or it should know it uses external source, I guess it would be a separate mode.
(2,801 Views)
