Kadtronix USB HID
Hello Everybody,
I am having some difficulty getting the Get List.vi to find the usb devices on my PC. It does not find any of my devices, and I suspect it may be with how I have the vi set up.
I think the problem lies with the struct data type:
 typedef struct {
    char         *DeviceName;   // Device name
    char         *Manufacturer; // Manufacturer
    char         *SerialNumber; // Serial number
    unsigned int VendorID;         // Vendor ID
    unsigned int ProductID;        // Product ID
    int          InputReportLen;   // Length of HID input report (bytes)
    int          OutputReportLen;  // Length of HID output report (bytes)
    int          Interface;        // Interface
    int          Collection;       // Collection
   } mdeviceList2;
Any suggestions?
There are some demos at the bottom of the page located here, and where done in CVI and work fine:
http://www.kadtronix.com/usbhidapi.htm#Description
(3,165 Views)
@bry0n wrote:
Hello Everybody,
 typedef struct {
   } mdeviceList2;
Any suggestions?
Well!! The mdeviceList parameter is an array of mdeviceList2 records. You only pass a single record to the function. This can work if you always pass 1 for nMaxDevice but if you pass anything else you will most likely receive an error (if you pass 0) or cause a memory corruption (if you pass more than 1 and the function has more than one device to report).
Rolf Kalbermatter  My Blog
(3,145 Views)
Thanks for the reply rolfk! I will give that a try.
(3,123 Views)
