Keep DHCP address if server is unavailable
I've posted a similar question earlier, but the fact that there is a way to achieve what I want on a Windows machine might shed a light on what I'm after...
If you set a Windows machine to not ping its gateway it will keep its previously assigned IP after r...
Is there a way to do this on a VxWorks based Real-Time controller (cFP-2220 in particular)? So far we've implemented a similar, but less efficient and robust method for this based on the System Configuration API...It would be much better if the in-built DHCP client could be set to behave like this.
Message 1 of 1
(2,436 Views)
