Keep matlab open after doing some calculations over ActiveX
I am using LabVIEW 7 Express and I am trying to interface with MatLab to do some calculations. The connection works fine, but when I stop the software, it closes matlab, which is a bad thing. Is there a way I can keep matlab open after the labVIEW software stops? Any thoughts would be appreciated as long as it does not involve placing the matlab script in a script node.
(2,615 Views)
I have not investigated this angle myself because I do not have Matlab on my machine. What I am thinking is calling Matlab via ActiveX Automation Reference rather than using the node in LabVIEW. This will be a particullary challenging way to solve the problem but it will allow Matlab to remain open after LabVIEW exits. You may need to dig through mathworks site for more specific information.
(2,615 Views)
I have found exaclty the same problem with all versions of Labview and matlab 6.5 (running in /automation mode). It appears that Labview closes TWO ref nums instead of 1.
A simple solution - when you start matlab get it to run a script which does
KEEPME = actxserver('matlab.application');
As long as KEEPME is not cleared, then the matlab sessions remains valid. I will report this bug to NI who are also trying to fix a problem with Matlab 6.5 - without previous installations of earlier versions of Matlab then there is no communication either through activex or through script. Doing upgrades from earlier versions works fine though : it appears to be something related to IDISPATCH interfaces.
Marc
(2,615 Views)
