Keep stay Support files after unintalled build
Hi All,
After uninstalling build usually support file will be removed from C:\ drive. But i dont want to lost the support file data. when i uninstall the build, only that application should be removed not support file which i included while creating EXE. After uninstall the build also i need to keep the support file in the same location. Is there any way to do that. If anyone knows please reply it.
Thanks in advance,
Manoj
(2,410 Views)
If you build an Installer there is an option available: Run executable before uninstallation. You could easily build a program which copies the required files to another directory to protect them from getting removed by the uninstaller.
(2,382 Views)
First of all thanks for your reply.
That's great idea but i dont want to store the file to another location. i want to keep the files in same location is there any other method to do that ?
without running any batch file from  labVIEW (Run executable before unistallation) is there any other method to solve this issue ?
Manoj
(2,361 Views)
