Keep the thread of the fist execution of a DLL for next calls
Hello everybody,
I'm developing a driver for mongodb in top of mongo c driver. The question is that the mongo c driver isn't thread safe, so I should execute it in the UI thread, which isn't convinient.
I have found posts about how to limit the number of threads in some "execution system" (like other 1 or other 2), and then wrap the DLLs in subVIs that execute in the modified execution system. But that sounds a little bit tricky. You have to configure each Labview instance & executable where you want to execute the driver. And there isn't room for multithreading.
There is a way to, during runtime, keep the thread of the fist execution of the DLL and then use it for the next calls?
Thanks for your time, best regards,
EMCCi
(2,321 Views)
Hello everybody,
I have a DLL (mongo-c-driver) that has functions like this that asks for the address of a uninitialized variable: "child MUST be an uninitialized bson_t to avoid leaking memory."
In a tutorial is used like this:
bson_t      child;
bson_append_document_begin (..., &child)
How I can  reproduce this in labview?
EMCCi
(2,312 Views)
I don't think there is a way to do that.
I'd look at C\C++\OS ways to do this. For instance, pass a pointer to class with a mutex and a conditional variable, and pass it along the parameters to each function...
See how-to-make-a-c-wrapper-api-thread-safe.
(2,312 Views)
