Keeping front panel objects aligned on target machine
I have a simple little program that looks fine on my development station but looks like crap on the target machine.
Indicators that are aligned on the dev machine are not aligned on the target machine?
I don't get it, why does it look so bad on the target machine? Worst of all is everyone sees the target machine so it makes me look bad!
Message Edited by RTSLVU on 08-06-2008 10:42 AM
=== Engineer Ambiguously ===
Message 1 of 12
(4,579 Views)
Your Dev machine and Target Machine have Default Fonts (and/or System Font, Application Font, etc) set up differently, causing the indicators to line up differently. Make sure all of those are the same.
Richard
Message 2 of 12
(4,551 Views)
OK so this is more a Windows issue than a LV issue.
Any idea where in Windows 2000 the default, application or system fonts are set?
Message 3 of 12
(4,546 Views)
No, not Windows, LabVIEW.
  1. Delete the VI on target.
  2. On both machines, in LabVIEW, make sure all the fonts mentioned are the same type and size.
  3. Bring over the fresh VI from Dev machine onto target.
Richard
Message 4 of 12
(4,542 Views)
I don't have LV installed on the target machine.
Only the LV runtime and the LV built EXE are installed.
Message 5 of 12
(4,536 Views)
AH! Then you have the well-documented issue where you need the font types/sizes in the Labview.ini file. Search for it. You need something like this in the ini....
appFont=""Tahoma" 12"
where Tahoma is the font (recommended) and 12 is the size.
Richard
Message 6 of 12
(4,532 Views)
p.s. this is what I have on a 8.0 LV installation.
appFont="Tahoma" 13
dialogFont="Tahoma" 13
systemFont="Tahoma" 13
Richard
Message 7 of 12
(4,528 Views)
Hi RTSLVU,
These instructions worked for me:
- Open the VI front panel. Click in File > VI properties > Windows Size
- Enable: Maintain proportions of window for different monitor resolutions
- Disable: Scale all objects on front panel as the window resizes
Check if monitor resolutions are equals.
Klein
Message Edited by Klein on 08-06-2008 11:50 AM
Message 8 of 12
(4,526 Views)
The fact that his title bar font is bigger on one panel than the other points to a font issue IMO.
Richard
Message 9 of 12
(4,522 Views)
Is this what I need to do?
 http://digital.ni.com/public.nsf/allkb/65F76F247012DF68862562C70073BE06
Message 10 of 12
(4,515 Views)
