Keithley 2000 Resistance error 800
Hi
I'm currently trying to create a Labview program that can scan through 5 channels on a keithley 2000 multimeter with a 20 channel internal scan card to measure a 4-wire resistance.
I am using Labview 8.6 and a Serial RS232 port.
I can set up the mulitmeter using Labview, but it falls down whenever I try to take a reading and shows an error 800 - RS232 Framing Error.
Any help would be much appreciated as there doesn't seem to be many resources out there for measuring 4-wire resistance.
Jonathan
Message 1 of 8
(6,682 Views)
Please check the baud rate and confirm whether it matches with the device (device capablity)
Message 2 of 8
(6,674 Views)
Are you able to communicate using a hyper-terminal?
Message 3 of 8
(6,673 Views)
The baud rate is correct, I can communicate with the device by sending commands using Write. I just can't Read anything when I scan.
I don't know anything about hyperterminal to test that I'm afraid.
Message 4 of 8
(6,669 Views)
Hello Neblar,
There is an NI Developer Zone article that describes how to perform a Loopback test on a variety of interfaces.  A section in this article describes how to use Hyperterminal for a Loopback test.
When you receive framing errors, the first place to look is the communication on the line.  As serial data is transfered, there are start and stop bits in every byte that is sent, separating different frames of data.  This Knowledgebase article also has some further information.
In an earlier post, you mentioned that your serial communication settings are correct.  Have you checked whether the settings in Measurement and Automation Explorer match those in the Windows Device Manager?
George T.
Senior Applications Engineer
National Instruments UK and Ireland
Message 5 of 8
(6,638 Views)
Hi neblar,
The framing error mostly occurs due to baud rate mismatch. If you are confident then may be you are facing a signal degradation. Can you try using a shorter cable?
Message 6 of 8
(6,632 Views)
Also when you say you can write and not able to read, Can you induce a delay between write and read and see If get out of the error?
Message 7 of 8
(6,625 Views)
I'm using same multimeter you are, but i'm using gpib to conect with it. I've downloaded the driver, and it's all working good. Have you tried to reset the keithley with labview, after you innitialize it?
TN
Currently using LV 8.5
logo
Message 8 of 8
(6,624 Views)
