Keithley 2000 and 7002 with trigger link
Hello!
I am writing an application for the 2000 DMM and a 7002 switch system. The instruments are set up with trigger link. What I want to do is simply to load a scan list to the 7002, scan and read back the results from the 2000. Here is what I have so far in terms of SCPI (I have looked at the Keithley LV drivers but I think they complicate stuff + there are no high level functions for trigger link setup included):
DMM *RST
SW *RST
SW Open
SW Scan (@2!1:2!40)
SW :TRIGger:SOURce TLINk
SW :TRIGger:TCONfigure:PROTocol ASYNchronous
SW :TRIGger:COUNt 40
SW :ARM:LAYer2:COUNt 1
DMM :TRIGger:COUNt 40
DMM :TRIGger:SOURce EXTernal
DMM :INIT:CONT ON
SW :ARM:LAY1:SOUR IMM;COUN 1
SW :ARM:LAY2:SOUR IMM
SW :INIT
DMM :TRACE:DATA?
Please advise,
Stefan
(3,563 Views)
I should add that what happens after executing my code up until the second last row...is nothing.
The scan begins as expected if I press the STEP button on the 7002 front panel (after going LOCAL) which suggests I am doing something wrong with the initiation of the trigger layer. Perhaps.
/Stefan
(3,557 Views)
Solved! The only thing needed was to command the swithch
:TRIGger:IMMediate
after the :INITiate
(3,550 Views)
hi morgue!
I am doing a program like your, but with Keitlehy 2001.
To make the syncronization you wrote just these lines? I am doig this in labview, with the programs found in the drivers given by keithley but is not working properly. When I put the triger link, it scans and show just the first measure.
Do you still have this programm?
thank you
(3,081 Views)
