Keithley 2400 Trigger 2000
I have tried for a couple of days to let a Keithley 2400 source current and measure voltage and at the same time trigger a DMM2000 on which a current will be measured. This is for use in a LIV characterization. I�m using Labview but prefer to write directly to the bus instead of using the Labview drivers, which I find a bit complicated to use.
First I configure the 2400 with the following commands
*RST;
TRAC:CLE;
SOUR:FUNC:MODE CURR;
SOUR:SWE:SPAC LIN;
SOUR:CURR:STAR 0;
SOUR:CURR:STOP 0.1;
SOUR:CURR:STEP 0.0001;
TRIG:COUN 100;
SOUR:CURR:MODE SWE;
SENS:FUNC "VOLT";
FORM:ELEM CURR,VOLT;
TRIG:SOUR TLINK;
TRIG:INP SOUR;
TRIG:OUTP SENS;
Then I write the following to the DMM 2000 to initialize
*RST;
TRAC:CLE;
SE
NS:FUNC "CURR";
TRIG:SOUR EXT;
TRIG:COUN 100;
Now the two instruments should trigger each other.
I then write to the 2400 to turn on and initiate the sweep.
OUTP ON;
INIT;
And finally an INIT is sent to the DMM2000 to initiate this instrument
This starts the measurement ONLY if the instruments have been turned on just before the program is executed.
If I run the full program again it doesn�t start. What is wrong?
If I run the program from the initialization of the 2000 it works well. But if the intialization of the 2400 is included it just wont start the sweep.
Any suggestions?
Regards
Francis
(5,148 Views)
You may wish to try this. I struggled with a 2400 for some time. After a single reading, the buffer in the 2400 contains current, voltage, ohms, a timestamp and another variable. You have to read the entire buffer of the 2400 or it ignors future commands. I struggled with the 2400 drivers also. The help files of the drivers did not describe one of the variable inputs. Finally, I figured out that it was leaving data in the buffer. I increased the variable to read all five values and it finally worked!
You will have a different solution because you are not using the drivers. But I suspect you may have the same problem. You will have to write commands to be certain you extract all measurment information for the reading. Perhaps the DMM may also have a simi
lar feature. If you do not read all the data, the systems will hang.
(5,145 Views)
I would call the guys at Keithley or send them an email. Try Al Ivons at aivons@keithley.com or call him at (800)552-1115 ext 2936. He has helped me with the 2400 many times.
kph
(5,145 Views)
I am a research student and has just started using LabVIew i urgently need to build a VI for the LIV measurement i am also using Keithley 2400 if u have developed the VI can u share it.
Regards
Neetu Chopra
(4,914 Views)
Hi Neetu,
A search on ni.com/idnet shows that Keithley has a LabVIEW instrument driver for the 2400. See the link below for more information.
http://sine.ni.com/apps/we/niid_web_display.download_page?p_id_guid=E3B19B3E941C659CE034080020E74861
Ebele O.
(4,900 Views)
