Keithley 2400 sine wave voltage generation
Hi everyone,
I want to generate a sine wave voltage and read current with Keithley 2400 source meter. Is this possible? If so, can you help with a simple scheme?
Thanks!
Erdinc.
(2,348 Views)
Hi erdinc,
you can do this step by step:
  • Set an output voltage
  • Read the current value
  • Back to step 1
(2,324 Views)
Wow,
This is the best solution I have heard about this problem.
Thanks!!!
(2,300 Views)
Hi erdinc,
What kind of answer do you expect with this little information from your side?
(2,297 Views)
