Keithley 24XX Read Multiple Example
Attached is the Keithley 24XX read multiple example from the drivers. I have modified it slightly to record a data point every second using 4-wire measurements. The only type of data I require is resistance measurements. Right now I can only set the test duration by specifying the amount of points to acquire (ie. for a 10 minute test I would put 600 into sample count with 1 second delay between each sample count). There is a delay between the program and sourcemeter for every sample count so I lowered the delay slightly below one second. It does throw my values off in real time but that is ok with me. The downsides are once I run the program it must acquire how ever many sample counts I specified to collect all of the data (if I stop it before allowing it to finish then no data will be given), and I can not see the results in real time such as the resistance values being plotted on a graph during a run. So my question is if anyone knows how to get the resistance values to be plotted in real time during a run, and how I can get the program to stop when I want to while also providing the data that has been collected in the VI that is attached.
Thank you
(1,762 Views)
As you can see you need an actual program not just a modified example code fragment.
A simple State Machine is probably all you need.
States could include but are not limited to:
  1. Configure instrument to take a SINGLE measurement
  2. Take a measurement
  3. Display measurement
  4. Save measurement to file
  5. Wait until next measurement interval
  6. Go to 2 until done
=== Engineer Ambiguously ===
(1,754 Views)
