Keithley 2701 - Remote Triggering the Master Limit
I am making a program that requires me to remotely flip the DMM 2701's master limit. I found the command needed to do this from the manual (CALCulate3:MLIMit:LATChed <b>) where <b> is ON or OFF. I have tried this command in the VISA test panel from within NI MAX as well as in the "EXECUTE REMOTE COMMANDS" section of the instruments website but even if I get a response from the instrument, the master limit latch does not switch.
Any advice on how to proceed with this issue would be greatly appreciated.
Thank you.
(650 Views)
Are you measuring the voltage between pins 5 and 9?
As this output is a latch, what is the default state (ON/OFF)?  Maybe you need to turn it OFF rather than ON.
I would issue a reset (*RST\n) to the instrument and monitor its voltage to understand how it may currently be set.
It looks like that command (CALC3:MLIM:LATC ON) will only latch the output when set and not physically change the output state.  It might be something like: (CALC3:MLIM:STAT ON) if I follow the previous commands for the other limit states correctly.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(616 Views)
