Keithley 27XX Error 170, 101
I work with Keithley Libraries 27XX. We have to connect the list with channels, like string separate by comma (like in 1LV attacment. I mean we have to chose string constant from palete, and type manually), but if I connect like indicator, there is a error (170 and 101, 2LV). I suspect, it can be problem with strings formats. If I would copy from indicator, and would paste to constant, It would be no problems. Do You have any ideas? Thanks in advance.
(5,095 Views)
Hi hepko,
as long as you only show images instead of real code you need to debug your code on your own.
I would start at the place where the (offending) command is send to your Keithley device!
(5,090 Views)
It looks like you are sending an invalid command and/or using invalid characters. You need to read the manual and use the correct command syntax. Without seeing your code, there is nothing else I can do for you.
(5,073 Views)
The 2700 accepts various channel lists with different syntax, Range uses ":", individual channels use "," like shown.  Without your code its impossible to tell if you plugged your string into something that is expecting a range or list of individual channels.
Also look at the termination characters you are sending (LF, CRLF, etc..) and if your string has a space at the end.  Use code display in the string to see if it ends in "\s".
If you post sample code, more help can be provided.
(5,034 Views)
I collect avalible channels (1-40) from loop, then, I am saving 2 types of data to 2 buffors (voltage and temperature).  After simple code execution, I have a channel list (for example 101,102,103), but if I would connect, there will be an error.
(5,022 Views)
Hi filip,
please attach your VI with a typical set of data!
Your image shows code which seems overly complicated for this task…
(Why do you use a format string of "%g" for strings?)
(5,019 Views)
 You are doing some very useless operations in your code. The for loops are useless and using an empty string constant as a separator for the Array to Spreadsheet string vi might not give you the expected result as it is inserting a space character instead as a separator. Feed your channels array directly to the Array To Spreadsheet String vi, use a comma as separator (and %s as format) and use the Trim Whitespace vi at the output to remove the carriage return added by the Array To Spreadsheet String vi.
Ben64
(4,995 Views)
