Keithley 3706A - How to program an iterative DMM measurement (isolation test)
I am using a Keithley 3706A DMM/Switch system. I want to perform an isolation test, i.e. a two-wire ohm measurement of every pin on my connector to every other pin. Originally I was going to use the Keithley "scan" function using "channel patterns" but after a month of no sucess with that approach, I want to try the old fashioned iterative approach.
I want to test every pin to every other pin. What is the programming archetecture I should pursue? I am currently thinking I should use some kind of nested for-loop.
So, pin 1 is tested against pins 2-42. THen it switches to pin 2 which is tested against pin 3-42, etc......
What is a general labview approach for acheiving this?
Ali
(3,166 Views)
I'd say your FOR loops are a good way to go.  Just leave a way for the user to abort (show the conditional terminal on the FOR loops and read a stop button inside of the inner loop).
The other option is to have a file with all of the connections listed and limits.  Read the file and then run through a single FOR loop that iterates through all of the connections you defined in the file.
(3,158 Views)
