Keithley 6221 ac and dc current source can't be triggered using labview program
I am using the in-built labview program KE622x.lvlib for keithley 6221 dc and ac current source. I wanted to generate a sine wave with an offset. That's why I used KE6221--Wave Gen Example,vi program for this purpose. But the problem is when I tried to run the program it showed 'the wave is armed' in keithley display, but it couldn't be triggered.
What should I do?
(3,036 Views)
Hi SA92,
the program it showed 'the wave is armed' in keithley display, but it couldn't be triggered. What should I do?
What does the manual of your Keithley say about triggering the waveforms? Which commands do you need to send?
Does your VI send that command?
Do you use the Keithley driver from IDNet?
(2,958 Views)
