Keithley 6487 Driver That Does Not Use IVI
Does anyone know if a driver set has been developed for the Keithley 6487 that does not require the Keithley IVI? To date I have been using .llb packages to control instruments and would prefere to use one in this case if possible.
Many Thanks
Ben
(2,824 Views)
Hi Ben,
Thank you for contacting National Instruments. Please only post once as posting the same question many times divides the effort of the group and generally results in a longer resolution time.
Duplicate post
Andrew McLennan
(2,806 Views)
     Appologies, this was my first post and i posted within the wrong forum. I had intended to post within the "Instrument Control (GPIB, Serial, VISA, IVI)" forum instead.
Many Thanks
Ben
(2,801 Views)
