Keithley 6517B I-V staircase sweep plotting data
I think my code works now so I'll just accept this as a solution
Message 11 of 14
(1,213 Views)
Ok, post if there's anything you want to improve in your code.
BTW, did my code work?  I haven't got access to my 6517a for a few days to test..
Message 12 of 14
(1,210 Views)
I cannot open your code there seems to be a subVI that's missing. I'm only using background noise so I won't know that it actually works until I get real results. Here's mine It  should work for what I need
Message 13 of 14
(1,208 Views)
LabVIEW tip - When you open a LabVIEW file with subVIs on a different PC, it needs to find the subVIs if they are at a different location.  Just use the "Browse" feature when the dialogue comes up to locate subVIs, select the proper location on your PC.  You usually only have to do that once or twice for instrument drivers and then it finds all of them.
Instrument Programming Tip - Run your code with a resistor (50Ohms/1W) across the terminals.  Use V=iR to ensure that you're code works.  Nothing worse than writing and debugging a lot of code that doesn't work because you didn't setup an easy test case.
Message 14 of 14
(1,205 Views)
