Keithley 6517b con gpib
Mi sto approcciando da poco all'utilizzo di Labview. Mi servirebbe sapere se qualcuno abbia qualche sistema per acquisizione continua delle misure tramite un Keithley 6517b collegato grazie ad una Gpig. Questo sistema deve essere in grado di dare come risposta la misura rilevata, salvarla e riprodurla grazie ad una coppia di assi cartesiani.
Grazie mille della disponibilità
Message 1 of 10
(3,145 Views)
Hi Enzo,
benvenuto in the LabVIEW board!
@Enzo4 wrote:
I'm just starting to use Labview. I would need to know if anyone has any system for continuous measurement acquisition via a Keithley 6517b connected thanks to a Gpig. This system must be able to respond to the measurement taken, save it and reproduce it thanks to a pair of Cartesian axes.
When starting with LabVIEW you should consider all those Training resources offered at the top of the LabVIEW board!
Later on you may look for your device at ni.com/idnet. There you will find a ready-to-use device driver with (probably) an example included…
Message 2 of 10
(3,139 Views)
Non sono riuscito a trovare nessuno drive che soddisfi i miei requisiti. Tu sapresti consigliarmene qualcuno? In modo da provarlo direttamente con lo strumento
Message 3 of 10
(3,117 Views)
Hi Enzo,
it really helps to write English in a worldwide forum…
@Enzo4 wrote:
I couldn't find any drive that meets my requirements. Can you recommend anyone? So try it directly with the tool
When I search for "6517" then I find a suitable driver in the IDNet…
Message 4 of 10
(3,111 Views)
Keithley 6517b con gpib? Mi potresti inoltrare il link?
Message 5 of 10
(3,096 Views)
Hi Enzo,
@Enzo4 wrote:
Keithley 6517b with gpib? Could you forward me the link?
What's wrong with looking for "6517" in the IDnet? Have you tried the presented device driver?
Message 6 of 10
(3,089 Views)
It don't have GPIB adapter in its accessory list, GPIB-USB-HS - NI should be ok, but it seems become more and more expensive...
Which kind of parameter do you want to measure continuely? it also support RS232.
Message 7 of 10
(3,066 Views)
Tensione/corrente/ e carica. Per il momento sto utilizzando solamente la Gpib collegata al keithley 6517b. Hai per caso qualche esempio da provare oltre a quello su ni.net?
Message 8 of 10
(3,041 Views)
It seems much more easy to do without Resistance/Resistivity, there is a reference manual on tek.com, it instruct how to do the programming by SCPI command.
And you also could try below driver.
Keithley 6517 Meter - IEEE 488.2 (GPIB) Driver for LabVIEW - National Instruments (ni.com)
Message 9 of 10
(3,037 Views)
Hai qualche esempio di progetto (in .vi) da provare?
Message 10 of 10
(3,030 Views)
