Keithley DAQ6510
I have a Keithley DAQ6510 Data Acquisition/Mulitmeter System. I am trying to create a labview code that will constantly acquire an emg signal and record the data. I am having an issue using the DAQ assistant in labview. Is it not compatible with the Keithley DAQ6510? I am clicking Acquire Signals, Analog Input, Voltage, and then it is saying there is no compatible device connected. Is there another way to acquire Voltage signals without using the DAQ Assistant?
(5,273 Views)
The DAQ assistant only works with (I believe) NI hardware. What you want are the 3rd party drivers found here:
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=6989F117B26B07CAE05400144FF8B5...
(5,249 Views)
Hey,
I have one of those Keithley DAQ6510. I've download the driver, but I still cant read data for it. It just get stuck in the "read multiple points vi".
Any help will be much appreciated.
thanks, Erez
(4,600 Views)
