Keithley DMM DAQ6510 unable to group channels based on seperate functionality
I am trying to read the parameters(Voltage, Resistance, Temperature ) simultaneously. using the driver we can define one functionality at a time. because of that sampling time goes to 3sec apprx. kindly help fixing and running all the functionality same time. kindly help in that.
(1,037 Views)
Hi Team, We are trying to read voltage, resistance and temperature which are connected on the separate channels of the DAQ6510 through Labview application. The official driver from Keithley doesn't have option to read multiple function in a single scan. Which means it reads Voltage in all channels, in first scan. Resistance in all channels in second scan and so on. It creates a delay of 1 sec between each scan. It cause of overall delay of 3 sec after 3 scans.
We have a requirement to read voltage, resistance and temperature within 1 sec which is possible if all the functions (voltage, resistance and temperature) are read in a single scan. Please let us know how can we group the channels with different functions in the NI applications to read all the channels in a single scan.
Denny
(1,003 Views)
