08-23-2021 11:19 AM
Hello!
I have a Keithley Nanovoltmeter Model 2182A and RS-232. I need to build a simple code to read, store and build graphs from the nanovoltmeter data.
I configured the 2821A as per the manual and data.
Here is the configuration of the RS232 of the 2182:
baud rate: 9600
Flow control: none
TX Term: CR
Here is the configuration of the with port of the program:
baud rate: 9600
stop bits: 1
date bits: 8
parity: none
Flow control: none
TermChar End-of-String for receiving: CR
TermChar End-of-String for sending: CR
Even though I made the settings and changed the port on the instrument, I got no response.
Are there any specific labview drives for communicating via RS-232? Looking on the site I found only this one for GPIB.
"LabVIEW Plug and Play IEEE 488.2 (GPIB)"
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=5340
One of the errors he got in one of the configuration attempts was ERROR 85.
08-23-2021 02:17 PM
Hi Lucas,
08-25-2021 12:20 PM
Thanks for the answer.
I tried running to do some reading. Got two errors, one in labview and one in keithley.
The error in labview was "Error -1073807339 occurred at visa read in keithley 2182a.lvlib:Initialize.vi -> Keithley 2182 Relative Measurement.vi"
The error in Keithley was "Error +803 RS-232 Break detected".
Would anyone know the reason for these errors?
